Stripped torque converter bolt!!!
Old Aug 31, 2012 | 01:24 AM
D14HUGGER.ORANGE's Avatar
Default Stripped torque converter bolt!!!
Changimg out my stall and stripped out my torque converter bolt. What do I do?!?
Old Aug 31, 2012 | 01:52 AM
lt1-xjs's Avatar
Retap the hole and buy a new bolt.
Old Aug 31, 2012 | 01:59 AM
jc98ss's Avatar
but if you go with a slightly bigger bolt, would that be enough to throw off the balance and cause a little vibration?
Old Aug 31, 2012 | 07:49 AM
Circle-D's Avatar
You can use a hell-coil repair thread so it uses the same diameter bolts.
Chris
Old Aug 31, 2012 | 08:08 AM
01Z0H6's Avatar
Ouch,... never good..
Old Aug 31, 2012 | 10:50 AM
jimmyblue's Avatar
Moderator
I would drill and tap them all identically, and use three
matching bolts.
Old Sep 1, 2012 | 07:03 PM
Thanks for yalls input. Correct myself I stripped out the hex head on one of my torque converter bolts trying to remove the stock converter!!! I dont know how imma get it off? A cut off wheel?
Old Sep 1, 2012 | 09:14 PM
therabidweasel's Avatar
I think if it were me I'd grind the sombitch down and use it as an excuse to buy a new flex plate too.
Old Sep 2, 2012 | 12:28 AM
jc98ss's Avatar
drill the stripped head out with a bit that's near the same size as the threads
Old Sep 2, 2012 | 02:15 PM
Hmm im not sure if I can get a drill inbetween the space. A small cut off wheel maybe?
Old Sep 2, 2012 | 04:10 PM
MUSTANGBRKR02's Avatar
Hammer and chisel. Hit it at the angle that would loosen it.
Old Sep 2, 2012 | 06:42 PM
black00ssFL's Avatar
Same thing happened to me the first time I did a converter swap. Ended taking a dremel with a cutoff wheel and notching a V into the bolt....as if you were taking a slice of pizza out of it. Then I took a small chisel and hammer, put it in the V and angled it to make the bolt turn counter clockwise, and gave it a good couple of blows. It loosened up and I removed it by hand after that.
Old Sep 3, 2012 | 10:20 PM
jeremyfrank14's Avatar
Air hammer to break it loose...
Old Sep 3, 2012 | 11:06 PM
mrvedit's Avatar
Moderator
I suspect this advice is a bit late, but take all your 12-point sockets and put them in the back of the drawer, out of harm's way. Always use 6-point sockets on 6-sided bolts. Only time I use 12-point sockets are on 12-point ARP bolts.
I thinks black00ssFL's advice is good.
Good luck.
Old Sep 4, 2012 | 09:54 AM
jimmyblue's Avatar
Moderator
If you can get a bite with Vise-grips, good and tight, then
whack the tail with a hammer, there's your shade tree impact
wrench.
