Advise Please!!
Old Sep 4, 2012 | 08:24 PM
99ls1zam's Avatar
Default Advise Please!!
Ok guys ive had terrible luck with this junk 4l60e transmission. It started back in january when i lost 3&OD. I got it rebuilt using an upgrade kit from pro-built automatics adding a 3600 stall and transmission cooler. Three months later i lost 3&OD again. (not daily drivin) Well i DO NOT want to continue running this transmission anymore and my question for advise is what transmission do YOU think i should run being weekend driver and highway driven. Alot of people tell me my cheapest strong way out would be a th350/400 but i kind of want to keep my OD for the highway. Would it be worth it? Is there another strong reliable transmission with OD thats fairly priced i could go with? ANY suggestions are greatly appreciated.
Thanks guys!!
Old Sep 4, 2012 | 08:37 PM
330oldsmobile's Avatar
Why dont you want to buy a built L60 just for the cost reasons?
Old Sep 4, 2012 | 08:49 PM
99ls1zam's Avatar
i had mine built to supposedly with stand 600hp and lasted 3 months. At the time i was at stock horsepower.
Old Sep 4, 2012 | 08:56 PM
garygnu's Avatar
a lot of people think they can rebuild trannys ,its not simple or easy.it take alot of experience and time to do a rebuild a tranny right.a good tranny rebuilder will stand behind their work and help you out.if the guy is a bs artist maybe sue him in small claims court.
Old Sep 4, 2012 | 09:06 PM
msydow's Avatar
im putting a th-400 in my car. there is no cheap way about it. i wanted a 4l80 but didnt see spending the money just to have the over drive.
Old Sep 4, 2012 | 10:43 PM
TXZ28LS1's Avatar
You just need it built by people who know the ins and outs of these trannies..
Go give RPM, FLT, Performabuilt a call..
Old Sep 5, 2012 | 11:27 AM
74novacustom's Avatar
I know where you are coming from. Its not easy to just keep pulling out the dead weight 4l60 trans time after time hoping someone will get it right. all the the while knowing it will never hold up to power.
Ive got over 2500 into mine with the many things that have gone wrong with it and thats not including the new B & M Fluid each time. and thats me doing the work time and time again..
Im driving mine now with no useful second gear under power while im having a th400 built....
Old Sep 5, 2012 | 12:11 PM
blk/slvr02ss's Avatar
Sounds like to me whatever your problem was the first time did not get fixed properly and i would get my money back and take it to someone who knows what there doing !
Old Sep 5, 2012 | 12:22 PM
heymoej's Avatar
we were on this merry-go-round a couple years ago & it was not very merry.....
RPM OR FLT........and be done.
good luck!
Old Sep 5, 2012 | 01:16 PM
maddoglou454's Avatar
Hello Sir,
Please call me at 770-781-0949 so we can match your application to your needs. I am sorry you are having issues. I would love to help.
What type of vehicle are you putting this in? Cam? HP?
Thanks guys!!
Old Sep 5, 2012 | 01:27 PM
00MaroonZ28's Avatar
At least your second build lasted 3 months. Mine didn't go that long. I did FLT and it's been flawless since.
Old Sep 5, 2012 | 05:09 PM
mrvedit's Avatar
Moderator
Obviously your 3/4 clutch failed (again), and this is a weak spot on the 4L60E.
Besides using a quality 3/4 clutch pack (which the upgrade kit may have had), it is also important to raise line pressure with a bigger boost valve and proper tuning, and make sure there is no pressure leakage to the 3/4 clutch. Furthermore, the 3/4 clutch clearance must be set correctly, the 3rd feed hole drilled to match the type of servo. If the engine revs past 6000 rpm, various mods are needed to the input drum and pump. Skip any of these steps, and the 3/4 clutch will fail repeatedly. A "stock" rebuild will NOT address all these issues.
The quality performance builders know all this (and more than me) and address all these issues with the correct combination of parts, mods, clearances and assembly.
In short, you probably have to pay $3K+ for a quality 4L60E, but that is still much less that buying a 4L80E, matching torque converter and mods to make it fit your car.
