th400 pump sealing washers and o-rings
I have just had to take out the pump on my th400 and realized there were little o-rings on each bolt and apparently sealing washers that should be replaced after every installation. I have look around and only found one place that sells them:
http://tsr-racing.com/shop/TH400/gas...ber+Components
does anyone know where I might be able to find them locally? like what size the orings are so I can go to Grainger or something? Or maybe there is a substitute that is just as good? what do you guys use when doing maintenance on these transmissions and have to remove the pump?
