anyone running a ss3600
Most people with 3.23 gears who are looking for a big 60' improvement and run nittos start with the SS3800.
i did run a 12.163@112.60 with nitto's spinning the 60ft, too hard to launch.
If you goto the track, get a buddies ET streets, 11.5psi, big burnout, and just stomp (brake idle, flash stall) the SS3600/3800 and you'll be quite pleased.
if you can smoke ET streets, well you got a badddddddd car or can't burnout.
I will no longer run nitto's because well they are my daily tires and don't last very long and whats the fun in going sideways down the 60 when i can just hook at maximum flash wtq.
You would think that the SS3800 must be weak just because many people run DRs with it? What kind of 60s are you pulling? I've pulled 1.51s on 275/40/17 Nittos.
Much depends on the track. I've spun 29" FULL slicks to the tune of 1.6 60fts on a slick track and I've pulled low 1.5s all night long with 17" Nittos.
I am hoping for 1.7s, but 1.5-1.6s are even better
I think you'd be happier with a 3800 than a 3600. Plus it'll leave alittle more room for other mods later on. Les
just curious as how it compares to the tci ssf 3500
