Sonnax HD 2-3 Shift valve install question
Old 02-03-2023, 01:35 AM
  #41
RobPH's Avatar
Thanks for the replies the sonnax fwd/rev abuse kit did come with a plug but it looks just like the OE plug so I had some transgo ones I thought it might be a good thing to use some they look like they would seal well buy don't know for sure... I used transgo low overun I think it's called yellow spring that came in the SK kit on other side of divider too for the fwd as the SK kit instructed and I am guessing the transgo approach of using steel ball with a spring does same thing as sonnax fwd abuse valve. The SK kit instructed to do the steel ball and spring with fwd torque valve but I used sonnax fwd abuse kit there instead with the transgo divider if anyone thinks I shouldn't for some reason let me know please thanks.
Old 02-03-2023, 12:38 PM
  #42
Tranzman's Avatar
I think your good to go!
The following users liked this post:
RobPH (02-03-2023)
Quick Reply: Sonnax HD 2-3 Shift valve install question
