Can I unbolt and leave out the center on TCI 399753?
I've got the stupid thick crank flange 2000 6.0L which calls for the 399754 flexplate, but my converter is the 10.75 powerglide bolt pattern, so I need the 399753 small pattern unit. If I can leave out the bolted in little center deal and use my old mid-plate shim at the bellhousing, looks like I'll be good to go. So I just need to know if it's kosher to unbolt the center piece from the 399753 and leave it out???
Thanks in advance,
TJ
Thanks in advance,
TJ
I am new to the LS1 world and can only refer to my experience with first gen stuff. But if you are referring to a boss that centers in the back of the crank don't run without it. If there was a way to index the crank and flexplate to converter with zero runout you would probably be okay, but I don't see how you would have enough room to do that. Just my opinion, but without the boss you could be slightly off center and then have a vibration that will start tearing up parts.
the TCI flywheel was designed to be used w/o the .400 spacer on the engines used when they had 4L80E's
with the long crank, you some how need to move the flywheel .400 toward the engine-i dont think that spacer is .400 thick, it was used along with a thicker flywheel to dup. a .400 meas
the starter wont match up
prob best to use a fact. 4L80E flywheel, or i belive someone makes an aftermarket replacement using the longer crank
i ran some high HP thru a stock plate, but you needed the small pattern, so you would need to redrill it
yeah, I ended up drilling on my stock replacement flexplate, seems to have worked fine today, went 10.34 @ 131 on it. The craftsmanship of the stock replacements flexplates leaves a little to be desired anyhow, so my work fits right in, lol.
thanks guys.
thanks guys.
