00 LS1 with 350 tranny help!!
Old Dec 7, 2012 | 06:54 PM
josephryan80's Avatar
Default 00 LS1 with 350 tranny help!!
I recently bought a 00 z28 ls1 with a 350 turbo tranny. Everythings pretty soild whoever did it, did it right. My problem is it tachs bout 3k at 65mph. I want sumthin that i can drive a hour away without it reving that high. It has a 323 gear in the rear the guy said. I was wondering if i should put a 700r4 tranny in it or what are my options?
Old Dec 13, 2012 | 07:23 PM
Any advice would be greatly appriciated
Old Dec 13, 2012 | 07:34 PM
Tattooed80's Avatar
Default Here
Depending on your power levels or future goals there are alot of options. If you are running a tv cable set up and want to keep it you can run a 700 or a 2004r, or you can go back to factory 4l60e or a 4l80e.
It really depends on budget, set up and of course personal preference...
What are the details on your combo or what is your end result? Are you staying stock? Etc...
Old Dec 13, 2012 | 08:49 PM
carlsonauto's Avatar
I would go 4L60E if the wiring is still intact. (assuming it was an auto from factory) Thats just me and Im sure other folks have different opinions...
Old Dec 14, 2012 | 08:16 PM
It was a 6spd from factory, but has been fully converted to auto. its got a few motor mods all bolt ons. Im looking for a quarter mile setup, something i could cruise around in and take to the 1/4 mile drag if i wanted to. what i know is its a LS1 motor, 350 turbo 3spd, and a 323 gear in the rear. far as budget im looking for the easiest and quickest change. thanks for the advice
Old Dec 20, 2012 | 02:50 PM
Should a 700r tranny bolt right up since it has a 350 turbo arleady in it?
Old Dec 20, 2012 | 08:29 PM
spicebird98's Avatar
the 700 should work fine, and it would give you overdrive. The 200 would work as well and would be a bit lighter than the 700 cuz its a smaller transmission. Might as well get it built up a little with clutches, shift kit, and shafts while youre at it if you are going to be racing it hard.
Old Dec 20, 2012 | 09:39 PM
snyousef's Avatar
Stick with a 700-r4 or a 200-4r (both are 4spd, the 700-r4 is essentially the non-electronic controlled version of the 4L60e), coming from the th350 it's the easiest/cheapest swap for you at this point....
Here's some good info http://www.maliburacing.com/auto_tranny_id.htm
Old Dec 22, 2012 | 09:54 AM
Thanks alot that helps a whole lot. Now to find a good trans.
Old Dec 28, 2012 | 09:53 PM
So i have a 87 s10 2wd and come to findout it has a 700r4 tranny in it. Does anyone know if itll work?
Old Dec 28, 2012 | 10:49 PM
Camaro396's Avatar
If you wanted a car to drive an hour why on earth did you buy a 3 speed equipped car lol. BTW my car with 3.73s was at about 3k rpm at 70 with 28" tires so I'd second guess that being a 3.23...probably more like a 3.73 or 3.90.
