4l60E Transmission difference 6 cyl
Possibly an issue with the accumulator in the case.
I wouldn't drive it much if it's so bad the rpm goes up on the shift.
Check the 3-4 shift valve, make sure the right spring is on it. and in the right order.
When I removed the valve body I did not find the single check ball that is supposed to be in the case. I am not sure if dropped it while removing the valve body. What this check ball for?
The fluid looks bad and something maybe cooked!
Might be time to tear that unit down and go through it.
What do I need to do to soften shift from 1-2 little bit ?
Will this little harsher shift actually extend whats left of the life of the 4L60E ?
Was the possibly the missing check ball my issue? What is it for ?
Thanks
It helps control the shift feel on the 3-4 upshift but more importantly helps the timing of band release on a 4-3 downshift.
I suppose it could cause some issues with 4th gear if left out. It's going to make the 3-4 shift feel softer than it already is...and it's going to possibly cause some funky timing on a 3-4 downshift that could cause accelerated band wear.
But I don't think that's really your issue here
If this (or several of the other checkballs) is missing, the gear will engage very abruptly. The check ball closes as the hydraulic circuit (clutch) is activated, forcing the fluid through a small metering hole in the separator plate for relatively gradual engagement.
When that circuit/clutch is deactivated, the check ball opens to quickly allow fluid out and quickly releasing the clutch.
For your Q about softening the 1->2 shift, the dome shaped cover in the trans is the 2nd gear accumulator. Three bolts hold it on. Remove the bolts, remove the accumulator and show us what springs and possible spacers are inside. We can then give you suggestions on softening the shift. However if the 2nd apply hole in the separator plate is drilled too big, it will have to be replaced (about $30). And as explained above, if this check ball is missing, the shift will be very abrupt.
Make sure there are no big washers underneath it; the Transgo Shiftkit comes with these washers, but Dana strongly discourages their use as it makes the shift too hard which can lead to trans and even driveshaft failures.
You could restore the stock springs to soften the shift; I don't have part numbers, but should be readily available, perhaps for free (plus shipping) from someone here.
Alternatively, if you have easy access to tuning software like HP Tuners, the 1->2 shift harshness can be reduced in the tune.
If I put the original springs back in like stock as shown below, will it shift little firmer than stock since I have a .500 Boost Valve and & the separator was drilled for 1-2 Shift to 0.082" ?
I did replace the piston with Aluminum version.
