will a powerglide bolt up to an ls1
Old Jan 20, 2013 | 05:27 PM
bungy74's Avatar
Default will a powerglide bolt up to an ls1
i do not know much about the newer engines, will they bolt up to a powerglide or a turbo 400 ?
Old Jan 20, 2013 | 06:05 PM
ctjohns's Avatar
yep, got one in my car. Just dont use the passenger side upper bellhousing bolt.
Old Jan 20, 2013 | 06:40 PM
Blackpanther99's Avatar
Yes sir they will.
Old Jan 20, 2013 | 07:09 PM
bungy74's Avatar
good to know, thanks guys.
Old Jan 21, 2013 | 01:06 AM
carlsonauto's Avatar
also see post 4 in this thread, the same basic deal applies
https://ls1tech.com/forums/automatic...-99-4l60e.html
Old Feb 7, 2013 | 11:29 AM
shepss217's Avatar
yup i think chevy used the same bolt patterns on all the trans except the 4l60e had a center bolt on the very top but is not needed
Old Nov 28, 2018 | 08:16 PM
Rick Baltierrez's Avatar
Default Powerglide bolt up
What did you use for the passing gear lever
I have a 68 camaro going with the 5.3 with ls1 setup stock 2 speed power glide..
much appreciated!
