4l65e with trans brake question for experienced racers
Was thinkin about runnin a glide just so I can use an Electric shifter and a brake, but then I started thinking.
Nobody seems to want my level 5 65e so why the hell not put a tbrake in it and run that? Well it will probably be shifting 3 times instead of 1 time in a glide.
My question is, If I put a trans brake in my 4l65e, can I leave it in "drive" and still have the transbrake applied in 1st/start? I really do not want to run my A4 shifter manually because it doesn't lockout like my Quarterstick
Thanks for any help.
Moderator
These threads might help you:
https://ls1tech.com/forums/automatic...ans-brake.html
https://ls1tech.com/forums/automatic...necessary.html
In the last one, it turns out sponsor Jake Performance will soon release his own 4L60E Transbrake kit.
Surprised nobody chimed in and said there is ratchet shifter with 4 speed gates out there. I picked up a TCI outlaw shifter from Summit the other day. I love the look and feel of this shifter. I may be buying a ross box soon for full manual shifts when I want them.
Thinking about running a 2 step in with my line lock on a clutch pedal setup and launch like a t56 car. And not using a tranny brake.
Anybody ever try that?
Outlaw shifter won't fit in factory console. Some modifications were required. Made a nice bracket for it. Cut my top A4 console out a little oversize. Can't wait to get it installed tomorrow. Ill post more pics soon.
