4l60e tuning w/speed density
Whats the advantages/cons of tuning with speed density vs thru the MAF?
ANY help would be REALLY appreciated.
Rick
The PCM will change the pressure in the trans (via the pressure control solenoid) based on "engine load". The PCM calculates this from some combination of the MAF, MAP, TPS and other parameters which are part of GM's secret sauce. When the MAF is disconnected, it is correctly calculated from the remaining parameters.
IMHO, at least one or two things in your trans and engine are seriously wrong. As a guess, it doesn't sound like your trans has enough line pressure and whoever has been rebuilding it hasn't checked it. When the tranny guy set your line pressure to 150psi, did he hook up a gauge or did he just make a hack and say that sets it to 150?
(He probably made this hack because he didn't trust the tuner.)
You can buy a trans pressure gauge on ebay for $45. It comes with a long 6ft hose. You can tie-wrap it to your outside mirror and drive around while monitoring pressure.
On the engine side, either the tune is way off, or there is a sensor problem.
Have you scanned the PCM for codes?
You may need to find someone that can log the PCM parameter while the car is driven, and of course monitor the real trans pressure. (The logged trans pressure is not real - it is what the PCM is requesting, not what you are actually getting.)
this in no way a stock tune, cam has .615 lift and .223/.239 duration....lq4. in my 66 chevelle, headers, ls3 heads, n intake... Right now has 2.73 gears, revmax 3200 stall. I have ordered new 3.42 gears and will be changing next week so that will help make things more like normal if I can get it to shift right...
Tranny shop did have a guage in it. I saw it when I took it for test drive.. This a shop that's been around since the 70's owned by the same guy....BUT, they usually work on stock stuff so some of this perf. stuff maybe out of there relm...
Talked to shop where tuner works, he's going to re-look at it week from saturday...henss, getting in the lower gears b-4 hand. Thanx...anymore thoughts?
Rick
I suspect the trans guy turned the shaft in the pressure control solenoid; not sure that can be undone accurately without buying another one.
If you don't mind the $45 for a trans gauge, I would recommend that. Search ebay for "trans pressure gauge 5550". Hook it up for driving when you take it to the tuner.
The tuner should then be able to hook up his scanner and force any desired pressure. This assumes of course that the 150psi hack is removed.
You are correct that even very experienced trans guys who mostly work on stock setups can be confused by custom mods and tunes. As James@ShorTuning pointed out, a failed MAF often results in max line pressure, but that is not the case if the MAF is simply tuned out.
the PCM commands line pressure based on the engine torque value it calculates from the VE table...
if the VE table is low then calculated engine torque is low causing line pressure to be low...
scantool can monitor engine torque (TRQENG) and commanded PCS pressure (TFMPRS, see note below for range of values)... look at these in addition to hydraulic line pressure (as said above) to see what is happening.
[ note: the PCM commands Torque Signal pressure (see Figure 44 on Page 47 of the HMTG) which ranges 0-96 psi, and pushes on the end of Boost Valve to increase regulated line pressure into the range 50-220 psi. ]
edit: corrected.
And now I have learned why the trans pressure tuning table has a range of 0-96. Thanks for the explanation.
(Although I thought stock line pressure can be as low as 50 psi.)
flywheel: keep us posted.
Unless you changed the injectors, the IFR should be right
VE - Volumetric Efficiency
This is the primary table tuned for almost any engine changes, especially different cams.
I believe Joecar is saying that strangely tuned engine parameters could lead to low transmission line pressure, leading to failure. The engine might even be working perfectly.
Rick
