4l65e
Old Feb 24, 2013 | 11:46 AM
time3777's Avatar
Default 4l65e
I just had my transmission rebuilt by a reputable shop, installed it myself now the car will not move in any gear. what could this be?
Old Feb 24, 2013 | 05:00 PM
pricesgarage's Avatar
if the converter isnot seated correctly you will break the pump on start up
Old Feb 27, 2013 | 10:21 PM
mrvedit's Avatar
Moderator
An incorrectly installed converter is the likely problem, and it true, it likely also broke the pump rotor.
This thread might help you:
https://ls1tech.com/forums/automatic...0e-my-ls1.html
See my post #8.
Do you remember if there was a gap between the converter and the flexplate?
When there is, you can turn the converter very easily before the first bolt is installed.
