First 4l60e rebuilt - a few questions
Wow! Thank you, Thank you, Thank you. I turned the transmission upside down and measure the clearance at tail shaft. It was 0.028 so I am good to go. I guess the Teflon rings were really tight and I am really weak. In reviewing my notes, I did not install a input carrier thrust washer. I can't thank you enough for all of the time and frustration you save me.
Thanks!!!
John
Thanks!!!
John
