1st time 4l60e build
Old Mar 30, 2013 | 07:25 PM
billybatty's Avatar
Default 1st time 4l60e build
New to the site, excellent info and posters. I have an easy question, but I know it has been the source of argument, but here it is. The sonnax servo check mounted on the 3rd accumulator port. Install the sonnax part or no?
Old Mar 30, 2013 | 08:26 PM
mrvedit's Avatar
Moderator
A assume you are referring to the Sonnax "Servo Release Check Valve".
I have installed it on the transmissions I have rebuilt, but cannot say I feel any difference in the 2-3 or 3-2 shifts. I believe some builders leave it out, but drill the 3rd feel hole to .120 anyway. I know many performance builder do use it. Also Sonnax is creating ever more performance parts for the 4L60E and I trust their research.
If you do install it, I suggest first tapping it with a 5/16 tap so that you can pull it out if needed.
Also, remember to drill the Orifice to .120 (or 1/8") if you are using a corvette or performance servo. Since the initial hole is quite small, I recommend drilling the hole in two steps.
Blow out all the metal shavings.
Then thread a 5/16" bolt into it and test the fit; if loose, install the supplied o-ring.
Old Mar 30, 2013 | 09:29 PM
billybatty's Avatar
Yes that's the valve I'm talking about. The reason I'm thinking about putting it in is to guard against the dreaded "2-3 flare". I will be keeping the 3-4 stack tight, around .020, I guess the question is is it "insurance"for my 3-4 stack. Nice idea on tapping it for future removal, too bad the 3rd accumulator wasnt tapped, which is what I had to do to get it out.
