Draining and cleaning a converter.
Old Apr 1, 2013 | 07:57 PM
custm2500's Avatar
Ph.D. in HUBRIS
Default Draining and cleaning a converter.
I am having the 60e in my Tahoe rebuilt. I have an 3200 FTI converter with around 3000 miles. I was planning on getting stock replacement from the tranny guy. He has been doing transmissions for 30 years and seems to truly know what he is talking about.
I asked him if he had a converter guy so that I could have the converter cut and cleaned. He said the common practice now event at the shop he works at is to drill an 1/8" hole in the converter, flush it with parts washer solvent. Then weld the small hole shut.
What is your guys thoughts on this? The converter was acting fine but I only had 1st and 2nd gear, that is why it is being rebuilt.
Old Apr 1, 2013 | 09:21 PM
duh's Avatar
duh
A 1.8" hole is not a small hole in a converter. But I wouldn't like that idea just in case something chewed up the lockup clutch. Personally I'd find someone that will open and inspect it. Maybe call FTI and see what it would cost just to have it freshened and go from there. Better safe then sorry and have to replace both in 6 mo cause something was left in there.
Old Apr 1, 2013 | 09:29 PM
djsanchez2's Avatar
wait 1/8" or 1.8" (nearly 2 inch) hole?
Old Apr 2, 2013 | 12:33 AM
Burken01's Avatar
eh your getting your tranny rebuilt and your going to add a flushed converter to it?
what if you contaminate your fresh transmission with particles and crap? not worth it if it were me.
Old Apr 2, 2013 | 09:12 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
We do not recommend doing it that way. There are a lot of risks that way and its not the most effective way to get all of the metal shavings out of the converter. We can do a cut, clean, and weld for $159 and you're guarenteed to be ready to go right back in the rebuilt tranny. Call us at 1-866-726-8358
Thanks,
Champ
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Apr 2, 2013 | 11:38 AM
duh's Avatar
duh
^ that is your best solution right there. Cheap enough and worth every bit of insurance with a newly built trans.
Old Apr 2, 2013 | 03:11 PM
custm2500's Avatar
Ph.D. in HUBRIS
I don't have the $159 plus shipping. I am unemployed currently and getting the trans done by scraping every last penny I have togather.
He can get me a stock replacement for just under $100.
Old Apr 2, 2013 | 03:12 PM
custm2500's Avatar
Ph.D. in HUBRIS
1/8" hole sorry my finger was one key off the first time. That is a huge differance!!!! duh hahaha
Old Apr 2, 2013 | 06:19 PM
Burken01's Avatar
even more of a reason to do it the right way.. if your trans goes down then your car will go down for a long time.. I understand your situation because I've been there before but if it were me I would wait a couple of weeks, sell some stuff on ebay or craigslist and gather the $160 and do it right..
Old Apr 2, 2013 | 07:28 PM
mrvedit's Avatar
Moderator
^^^ +1
There are a bunch of sad stories here about people paying good money for a rebuilt trans and then skipping cleaning the converter (and replacing the trans cooler). The result is a quickly failing trans and a looooong time before the car is on the road again.
Now, if there was absolutely no metal in the old trans filter and oil pan, and the mechanic will give you a written guarantee for the trans and converter combo, then you might consider that. Still risky though.
Old Apr 2, 2013 | 10:12 PM
custm2500's Avatar
Ph.D. in HUBRIS
I am getting a killer deal on the trans rebuild. We all know that knowing the right people is how you build a $50,000 race car on a working man's budget!
I am still debating on what way to go. I fully understand the risk.
I was dead set on him getting me a stock replacement till he have me the advice. If he will warent the trans rebuild for a reasonable time I will probably clean and install the converter. IF not I will certainly get the stock replacement.
