4L60e delay in forward gear Pros?
Yes, the boost valve can be replaced without removing the valve body. Depending on the year of the trans you may have to remove the pump. I think 2007 an up the pump has to come out.
Im trying to locate the pumps boost valve. Im guessing its above that connector for the turbine speed sensor in the upper right corner next to the rooster, and I have the model that doesnt have access to the boost valve....am I correct in that, or is there a work around?
I unfortunately have the model where the turbine speed sensor seems to be in the way of the boost valve, at least in my photo, the pigtail is in the way. Any work around, or does the pump need to come out/transmission removed from engine?
Also, is that the likely culprit? Seems to be the common denominator in the thread. How about the pressure regulator valve that resides in the same hole? Anyone had to replace the entire pump cover because the hole was bored out?
Probably some questions as I go, trying to get my ducks in a row before tearing this thing apart.
I'm sure there is one, but what is the purpose of unplugging that connector and retesting? Is that to deactivate the solenoids? First time I opened it up I replaced the solenoids for 1-2 and 2-3, did nothing. This time I'm trying to be near certain before opening it up again.
With your pressures up and down with the same RMP and load, has me thinking you had an electronic problem. May be MAF, TPS, MAP sensors or a defective EPC solenoid.
If I do that test, where should the pressure be at?
Also, I had it on a computer that was showing ecm to epc was showing the same values. This was before it was warmed up and having the issues though.
Your pressure should be higher than 75 and not fall the 45 when hot.
Pressure is not steady when it goes from 70 cold to 45 hot.
Also, assuming I can just remove the "tcm" fuse under the hood, right?
70-75 like when the transmission is cold in any gear(1,2,3,d,r).
I had a lot of parts because I didn't want tog back in, so I replaced the pump cover completely, pump body w an alleged good used one, looked machined. The rotor, veins, guide, slide, pin and springs. Rebushed the pump body that was used I bought. I was a little suspect of the pump body, seemed like the rotor and veins didn't quite move freely. Maybe should've went with the devil I knew......
Anyway so back together and seemed to run well for a couple days. Now, the main issue where I'd have to tap the gas to engage 1st gear, and there would be a bump felt, that issue issue is gone. But, I still get a low rpm, when shifting into gear. It'll go from a normal 620ish in P or N, down to 420, then bounce up to 520, then down 450, then finally settle in at maybe 500, and really feel like it's bogging down. Condition almost seems worse than before, as far as the temp doesn't need to be completely warmed up anymore (although it was starting to happen at lower temps, like say 140, even before the repair, and was rapidly getting lower by the week). But when it's bogging, if I tap the gas, it'll run and is in gear, no bump felt. This doesn't happen nearly as pronounced in gear, and say at a stop light now, even warmed up, but I can make it happen easily by putting it in P or N for maybe 5 to 10 seconds, and then going into D again. Happens shifting in reverse too, really any gear. I suppose it seems more pronounced because before the PR valve was catching and so the rpms would stay low, and then I'd tap it and it would run freely with that little bump into gear. One thing to note is that before repair, when I had the issue, the line pressure would go all the way down to 46psi, bump gas and it'd grab and recover. Now, same bog issue, bump since the pr valve is replaced (entire pump cover), the psi stays right at 64 withe the issue or not, but I still have to tap the gas to feel like a normal idle.
Before repair idle- I had 70psi in D, P, N when no issue present. Not sure about R o r2, but they may be close to the after results, could be a bit different though.
After repair idle- 64psi in D, P, N. Reverse is like 83, 2nd is 70. All pressure stays the same weather issue is present or not.
after repair- I also pulled the trans fuse, and psi is at 195 to 200 w the a/c off in park.
So I lost 6psi....Maybe the pump body being shoddy and slightly leaking? Could be warped and eating the rotor veins, especially when first engaged in D? I'm going to drop the pan tomorrow and see if there is any shrapnel, if it is sheering itself in there.
Further, I cleaned the throttle body, maf, map and tps. No difference and no codes on that front. Doesn't mean there isn't anything to it, but since this has been a transmission issue, and at least was based on temp, I'm still leaning either TC or that pump body being compromised going in.
If anybody has anything they can suggest to try, I'm open to anything. Like the first time, I want to pull the transmission, if I'm sure about the part I'm to be replacing. Outside chance of an engine issue, I'm looking at that too.
