4L80 flexplates
Old May 26, 2013 | 10:56 PM
Blackbird-WS6's Avatar
Default 4L80 flexplates
http://www.circledspecialties.com/p-...flexplate.aspx
VS
all the other flexplates on the market to use in a fbody
what are the weight savings between them all??
Old May 26, 2013 | 11:03 PM
JakeFusion's Avatar
Super Hulk Smash
CircleD is heavier than everything but the TCI... but we're talking about 1lbs difference between stock and aftermarket IIRC.
Chris posted up a chart one time that had all the aftermarket flexpaltes on it... Hughes, TCI, CAT, Reactor, CDS/Reactor, Stock, and something else. I'll see if I can find it.
Old May 26, 2013 | 11:04 PM
you have a link to the TCI one?
Old May 26, 2013 | 11:07 PM
JakeFusion's Avatar
Super Hulk Smash
https://ls1tech.com/forums/17400145-post9.html
Here is what I was talking about. You're not saving much weight or gaining much between any of them. I'd go with the CDS/Reactor Aluminum one or the Hughes... Which I think can still be used with the 4L80. At least I've seen it mentioned. Otherwise, TCI or CSR...
Old May 26, 2013 | 11:13 PM
ill need one for the 6.0/4l80 which comes in at 6.10 by the cart factory flexplate and the only one that beats that is the CSR at 5.22
Old May 26, 2013 | 11:14 PM
JakeFusion's Avatar
Super Hulk Smash
You're talking pretty insignificant weight tho - it's not like the torque converter or a flywheel where you shed a ton of weight. I want something that will hold together...
Old May 26, 2013 | 11:16 PM
true. i just wanted to know the weights between them all.
Old May 26, 2013 | 11:25 PM
JakeFusion's Avatar
Super Hulk Smash
I was surprised it was almost no difference.
Old May 26, 2013 | 11:45 PM
wonder how good the stock ones are. i know there not sfi approved. (408ci-150shot-4l80 with transbrake)
you dont hear many people swapping to aftermarket ones that much.
