performance switch
Old May 31, 2013 | 08:46 AM
KDD's Avatar
KDD
Default performance switch
has anyone tried to wire a performance switch like the trans ams have for the trans. I have a 98 ls1 auto camaro and would like to have the switch at the track.
Old May 31, 2013 | 02:31 PM
greenvortec97's Avatar
No trans am but mine has the performance or "tow haul switch" wired up.
I use mine for roll racing.
Old May 31, 2013 | 02:56 PM
mrvedit's Avatar
Moderator
Interesting. What pin on the PCM needs to be hooked up?
Old May 31, 2013 | 03:17 PM
JUSTINSWS6's Avatar
Doesnt it just take it out of od?
Old May 31, 2013 | 03:44 PM
SSZ-LS1's Avatar
The Power/Tow Haul switch select alternate tables for the transmission in the pcm, these tables include (for most calibrations) alternate:
Shift points (RPM & Speed, part & full throttle)
Shift pressures.
TCC lockup & release.
Torque Management
Desired Time for shifts.
Cheers
Jamie
Old May 31, 2013 | 04:12 PM
Blue pin 71
look at my threads I have a demonstration
Old May 31, 2013 | 04:23 PM
got-a-ls1's Avatar
yup im doing this as well. you can easily find a wire in your harness that has no use and move that pin and wire and use it. that way you dont need worry about buying pins and crimping them. unless you are bone stock there has to be 20 useless wires floating around haha..
Old May 31, 2013 | 04:24 PM
M6 guys hate me when they roll race me
