Are all 4L80E's the same.....all years......?
Like a guy locally selling one from a 1992 Chevy G-30 Conversion Van.
Are certain years better than others.....?
What's the best year to find....?
I'm looking for a cheap used unit to have rebuilt but the ads are misleading since I have conflicting info.
If the older ones will work that opens up my options locally then. I'd rather not have to eat shipping on one if I can avoid it.
Also does it matter at all if it originally came from a truck/van/car?
As mentioned, the early ones had a different connector which can be updated to the new style. You should be replacing the internal harness anyway.
In '97, the cooler return moved back to the center support. This can, in some instances, make running cooler lines more difficult if tunnel space is tight. In my experience, the newer lube strategy has no real advantage over the early ones.
In '01, they changed the OD sprag to one with smaller rollers. I prefer the early OD sprags, but it's not a deal breaker in my book.
So, mine will be getting FULLY built by someone at some point. I mean all the billet hard parts and whatever other parts are available to handle 1200 RWHP.
So.....which year 4L80E should I look for knowing that......? I just want to buy one of these "good condition" used ones from someone's van or truck.....put a shift kit in it and install it for now to use with my approximate 425 RWHP 390ci. Because my 4L60E is not gonna last long. Then when Modular Turbo gets my car for the Twin-Turbo project it will get pulled out and sent for its build.......
So which one.......I don't want trouble with running cooler lines either......it's going into my FBody.....
Thanks.
So they are plentiful, that's for sure.
What do you man LATER years a bolt hole was added in the center.......?
That's what I don't want right.....since I will have limited tunnel space....right?
1997 and later have one cooler line up front and the return comes in about 2/3 of the way back. If you have good enough access in the tunnel way back there, then it will work fine. Most conversions have limited access, especially that far back, so the earlier ones (1996 and earlier) are easier to plumb because both lines are up toward the front like a 4L60E.
Or will I need to keep the same 3200 size stall I have now so the engine can idle properly with its tune......since its crammed right now.
BUT...It is close enough to the parking pawl lugs to read off of them...it will read half speed...the computer DOES NOT like this...
I learned this the hard way on a swap...
