70 Chevelle wont shift out of first
I have reverse and when I put it in drive it will not shift out of first. I did not try manually shifting it. However I should note that I have been reading about a vacuum modulator and I know I DID NOT hook it up. I have done a LS swap and have no idea where this line goes. I understand this could be the problem. can someone explain to me where this vacuum line goes for the modulator? I also have no kick down switch, which I am to understand is fine.
Ok hooked up the vacuum line, still wont shift while in drive. But it will shift into 2nd gear manually. Or maybe I just havent been going fast enough. I have only taken it in my development about 25 mph. Do these TH400 shift at a certain speed or rpm? Or maybe the vacuum modulator is broken or stuck? Any thoughts?
Th400
You also want to check the nylon Govener gear. It could be stripped!
You can call us and talk to a live person. Up until 10 PM Eastern standard time , Monday through Sunday.
Thank You,
"Mad Dog" Lou
Mad Dog Transmissions
Phone 770-781-0949
Fax 770-781-0969 maddoglou454@aol.com
Web: www.maddogtransmissions.com
Facebook: www.facebook.com/maddogtransmissions
Twitter: www.twitter.com/maddoglou
YouTube: www.youtube.com/maddogtransmissions
Thank You,
"Mad Dog" Lou
Phone 770-781-0949
