pick me a converter COME IN CONVERTER PEOPLE
car is a turbo car with a trans brake and 4l80e. what stall should i get these people to re stall my converter to? its 3600# ~700hp on 15 PSI, and i run a 3.90 gear with a 28.5" tall tire
I would set it up per the combo, Not just what does it stall. A turbo converter is different set up than a NA converter or nitrous!!!
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
That's why I'm not a fan of cookie cutter converters.
I'm wondering what it stalls now, and what it is or isn't doing. Turbo combos can be a PITA to nail down because they need to be loose enough to allow spool but then tight enough to couple.
If you have to sit on the converter that long to get it to spool then you either have the converter set up wrong or the tune in left field or both!!! Not good If you sit on it long enough to cook the fluid!!!
Greg
Greg
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
