02 TA Trans problem?
Trans seems to "strain" on the 1-2 shift and TC is unlocking at highway speeds. Here is a link to a video of how she is behaving at around 70mph or so:
http://s70.photobucket.com/user/Wyat...a982d.mp4.html
Would sure appreciate some expert advice, do I have another rebuild in my future? Is this a TC going bad or hopefully something easier and less expensive to fix?
There are many threads on P1870 which describe the many options available.
In short:
1. Replace with an on/off TCC valve such as the Fitzall. $20 + labor
2. Rebore the VB for Sonnax oversize PWM TCC valve. $75 + special tools + labor.
3. Replace with used or rebuild valve body. $150 + labor.
And now my rant...
I finally found my receipt for the transmission rebuild, had it done Dec 2011. I've put less and 4K miles on it since then. The car only has 35K on it now and I do not abuse it at all -maybe that is the issue!
Frustrating to have these troubles out of such a low mileage and babied car. I finally found my receipt for the transmission rebuild, had it done Dec 2011. I've put less and 4K miles on it since then. The car only has 35K on it now and I do not abuse it at all -maybe that is the issue!
Frustrating to have these troubles out of such a low mileage and babied car.Unfortunately many rebuilds do not include a thorough rebuild of the valve body. If you want to do it yourself, we can help you; figure on 4-5 hours for a newbie. (And you will learn a lot.) A trans shop will probably charge you 2 hours labor for options #1 or #3, but much more for #2.
The Transgo HD2 shiftkit, the Sonnax Performance Pack all include a replacement for the troublesome stock TCC valve. Like the Fitzall valve, they all turn the TCC valve from PWM operation into on/off operation.
Since you plan to remove the valve body and replace the valve, you will find the Transgo HD2 instructions helpful and someone posted them here:
https://ls1tech.com/forums/automatic...questions.html
Page 3, step 1 is the HD2's replacement of the TCC valve.
Critical steps while installing the valve body are putting the check ***** in the right place (hold them with Vaseline) and putting the different length bolts in the correct positions. See Page 4 and 4 of the instructions.
It could be an extra one that someone dropped, forgot about and replaced. Or it could be one of the 7 that are in the valve body or the one in the case by the 3-4 accumulator.
No reason to think the valve body is damaged.
Using the previously linked HD2 kit instructions for guidance, I would suggest carefully dropping the valve body straight down so that the check ***** stay in position. Then you can determine if one is missing and which one. Worst case, just count how many fall out of the valve body. The 8th check ball is above the separator and drops out when you remove the last two bolts holding the separator plate to the case.
With the valve body out, I would still suggest fixing the 1870 code with either a shift kit or the Fitzall valve. At a minimum, also have new separator plate gaskets handy. Better, spend the $25 for the Transgo 46-PLT-96 universal separator plate and drill it according to the HD2 instructions even if you don't install the shift kit.
Carefully follow the HD2 instructions for the check ball locations -AND- for installing the various length valve body bolts in their correct position. For assembly use Vaseline to hold the check ***** in position; do not use grease.
