th400 vs 4l80e
Old Nov 7, 2013 | 01:19 PM
ls05mustang's Avatar
Default th400 vs 4l80e
im doing a turbo 5.3 forged rods and pistions 317s with a pt76mm billet and i am wondering what is the easiset trans to swap into a f body and what i need to do it thanks
Old Nov 11, 2013 | 08:10 PM
mrvedit's Avatar
Moderator
Sorry, but no one has answered you because there are literally hundreds of theads on swapping a TH400 or a 4L80E, and dozens comparing the TH400 to the 4L80E. The Search has a drop-down menu; select Advanced. Type in "th400 4l80E" and select just the Transmission forum.
Old Nov 11, 2013 | 08:29 PM
Carter01's Avatar
I can tell you a th400 is a piece of cake if you do your research. IMO I would go th400 because more than likely you will not need the 4th gear of the 4l80 because you will probably run a taller gear with the turbo setup.
