Anybody running a trans break in a 4l65e
Moderator
By the time you are making 700+ HP, you really should be thinking 4L80E, especially if you are serious enough about your ET to be wanting a trans brake. Just my opinion.
Call Carl Rossler. I have his Terminator 3 4l60e with transbrake , every option he has and it works like a charm. 800 + flywheel , nitrous ls1 , 3500 lb car. Have over 100 nitrous passes and fluid looked brand new when changed recently. He also has a "little black box" that plugs into trans harness if you want manual shifts. Same trans has held up for 5 years in a 4500 lb impala ss with 1500 hp blower motor. Check out Jeff Green Impala Ss. There was an article in Gm High tech little while back.
