Why 4L80/4L80e
I assume that if you are wanting that much power then you will either be turbo or a blower car. Forced induction, especially a turbo, works better with an auto. Boost doesn't drop off with gear changes, you can build more boost off the line on a trans brake in an auto than you can with a 6 speed.
https://ls1tech.com/forums/manual-tr...p-trans-3.html
Took a peak at that thread, damn man you weren't kidding about sheering engagement teeth off. Do you guys find it to be more so a lack of lubrication or (what I'm assuming) simply the compressive strength of the metal/engagement teeth is/are not up to the task?
It's also like Jake says, the primary weakness is the OD section, especially with the carrier and the conventional OD roller clutch.
