Tapping trans pan(4L80) for temp gauge?
There is different styles but I chose the one that has a little ridge/lip on it
Using a cone/step drill bit drill a hole in the rear of your pan right in the middle so it reads average trans temp.
Drill till the hole is big enough till the bung can fit in and stop after it hits the bung lip..
Then weld a nice bead around the perimeter
That's how mine was done
It's the auto meter one they sell for they're sending units as an option..
You can use any kind of bung as long as its steel, If using a stock pan..
The ridged ones just make it easier since they sit in the hole before you weld
I'm a terrible welder so i don't trust me doing it Switch as in when a heat problem is detected the sensors signal puts the trans into limp mode. A quick look at the internal harness showed a temp sensor.
