ditched the 4l60e for a th350, what to expect?
Here is the setup Im going with-
PTC th350 with upgraded clutches, drum and 36 element sprag
and deep pan
PTC 4000 10" converter
I won't run a ptc transmission.
Stop and go won't be much different. 50-60+ for extended amount of time Will suck.
Rear gears tire and converter Will play a large roll.
My exhaust used to be loud, and it sucked driving on the highway at 2000rpm. I can't imagine what it would be like doing that at 3000+ rpm
With a steeper gear the engine isn't working as hard.
And just because its bad at 2k rpm doesn't mean the exhaust Will be bad at 3k. I have horrible drone and its loud from 50-about 58mph.. From there up no more drone and quiets down.. The entire exhaust tone changes.
I love the driveability of the A4. I could go 4L80 but that's super expensive.
My car will be a weekend warrior at best. I'm thinking it's best to swap to a 3 speed for longevity since I plan on racing a lot. My friends want me to keep the A4 as they think I'll hate the A3.
I'll be following this thread for sure.
Lemons why don't you like PTC Transmissions?
Then if you add spray you're SOL unless you have a $2300+ 4L60. Even then from what I've read people whole race their car often usually have to do a rebuild after a couple to few seasons.
I wouldn't even want to lose the ability to lock the converter in the 4l60e on the highway.
If you want to know what it's like it's not hard, jump in a car with a 4l60e and put it in 3rd and set the pcm to not lock in 3rd gear. You will be at 3000rpm or more a lot.
