99 6.0 & 4l60e Trans - Looks like it will work, No?
I have a 99 6.0 engine and a 4L60E trans that has the bolt at 12 o clock - The 4L80E trans that was behind the engine also had the 12 o clock bolt. I measured the OD of the converter snout and the ID of the crank and they are the same, The converter looks to fit the hole in the crank fine. I left the flexplate on that came with the engine and bolted the trans up - I looked at the TC to flywheel bolt and it looks like if I slot the flywheel a little it will bolt up. As it sits the TC is about .080" - .100" away from the flywheel.
Not sure what the trans came out of but I posted a pic of the tag on it.
Any input is appreceiated.
LK
Flywheel / Back of engine
![](http://i925.photobucket.com/albums/ad96/alwhite00/White%2067/Photo0978_zpsbb2f7bc8.jpg)
Torque Converter
![](http://i925.photobucket.com/albums/ad96/alwhite00/White%2067/Photo0977_zps6a9d2fad.jpg)
Tag on trans
![](http://i925.photobucket.com/albums/ad96/alwhite00/White%2067/Photo0976_zps1491741d.jpg)
Bolt Mis-alignment
![](http://i925.photobucket.com/albums/ad96/alwhite00/White%2067/Photo0980_zps6daa0f87.jpg)
Bolted together.
LK
Torque Converter
Tag on trans
Bolt Mis-alignment
Bolted together.
![](http://i925.photobucket.com/albums/ad96/alwhite00/White%2067/Photo0982_zps7f16d57a.jpg)
Your trans is a 2001 silverado or seirra Ext. cab 4x2, for 5.3L.. 6.0 w/4l80 flywheels are different.. you will need to get one for a 4.8/5.3. pretty sure there thread on here bout 4L60 to 6L
You have the "flat" 4l80e flexplate. You need a "dished" ls flexplate. That converter requires the ls style flexplate. The 99 and 2000 6.0 motors have the infamous long crank flange. You will need to run a custom converter. If you remove the flexplate I can verify the type of crank you have
-Brian
-Brian
You can run an LT 4l60 and it'll bult right up .
04 GTO IBM A4. 1 of 273. 1 7/8 pacesetter long tubes. Pacesetter 3" catless mids. SLP LM2 catback. Vigilante 4500. B&M supercooler. IPS motorsports Dyno tuned @352/350
I got it figured out and i do have the "long crank"
https://ls1tech.com/forums/general-l...-did-pics.html
I had another thread with pictures. https://ls1tech.com/forums/general-l...-did-pics.html
The main problem was that the TC would not go into the crank far enough to bolt to the flywheel.
