Why do i keep buring up 3-4 clutchpack
The biggest problem with these trannies here I go again...is LINE RISE...or lack thereof. There are 11 input controls and 8 output controls on this trans all of them haveing an effect on line rise and shifting of this trans.Thats not mentioning any of the hydralic controls,even your filters have to do with line rise. All of this must be performing flawlessly. And none of it can be left out of the picture with reguards to 3/4 burn up.
I really do agree with the builder comment.....along with that is the shop owners, who's only concern is the bottom line. I do hope this helps and is not intended as a slam on anyone. yall have a good day.....Dave
Awesome job with the explanation...I have learned alot.
How would you fix or non responsive lazy line pressure ?
You see it here all the time "I got 85000 miles out of the original transmission, this piece of **** only went 2000 miles then 3/4 burned up." there soluation to the problem is to install a 350. when the whole time it was their tps, or mass air flow or a bad ground. Putting another set of clutchs in is not the cure. Adding a 350 maybe but it seems extreme to me considering we're at 2.00 a gallon. You've got to find the problem and fix it.
Their are many qualified persons who can trouble shoot these problems, even more who can not! Yes like hawkn01 said these pumps cavitate on the higher rpm band really bad, but what I see more than this is poor line rise.
Note: cavatation is a high rev situation, running a line check don't quite take in this problem, however it will give you a flat spot on top, when performing a line chek your not holding that rev long enough.
It is my hope that this is clear and is not intended as a slamb to anyone, I appricate you all and this fourm thanks ........Dave
As far as setting up the trans in ls1edit, it seems ideas are all over the place...dunno where to start.
