TCI Breakaway Converter
Here is the thread that JustAFool mentioned:
https://ls1tech.com/forums/automatic...t-fighter.html
Having used several TCI converters and now having a Yank, I know you will be very happy with it.
Your SS3200 will have a billet front cover with a much stronger clutch. However, to be on the safe side, your rebuild should include a Transgo or Sonnax shift kit with a revised torque conveter clutch valve that eliminates PWM.
Read this thread for a full explanation: https://ls1tech.com/forums/automatic...education.html
Now that I know TCI is not going to warranty it I plan to cut it open this weekend.
Thank for the info. I installed a Transgo kit in it the first time I rebuilt it, but I don’t recall anything about a revised torque converter clutch valve. Do you have any info on that?
https://ls1tech.com/forums/automatic...questions.html
The TG and Sonnax shift kits replace the troublesome PWM TCC valve with a simpler On/Off TCC valve. Most aftermarket converter companies suggest using a On/Off TCC valve to extend the life of their lockup clutch. GM uses a PWM valve so that the TCC engagement cannot be felt; I think most of us here prefer to feel it engage. (If you remove the check ball at the end of the input shaft you will feel it more like a shift.)
