1999 2wd silverado trans compatibility
Old Feb 26, 2014 | 05:49 PM
Taubr Unit's Avatar
Default 1999 2wd silverado trans compatibility
So my g/f truck is a 1999 2wd Silvo with a 5.3 in it. Has 188,xxx miles on it so the trans is slowly trying to shell out. Being a 2wd truck, will any fbody trans work or the computers different? It be nice to find a used trans on here thats built up some vs a bone yard find. Possible?
Old Feb 26, 2014 | 06:05 PM
mrvedit's Avatar
Moderator
All '96 thru '06 4L60E are electrically compatible.
More importantly, all '98 through '06 4L60E/4L65E for V8 engine (300mm input shaft and bolt hole in 12 O'Clock position) are completely interchangeable. An '03 - '06 4L65E would be your best bet, but just make sure it came from a V8 2WD vehicle.
Old Feb 26, 2014 | 06:27 PM
Taubr Unit's Avatar
that was the best answer ever, lol thanks! So being a 65e, the electronics from her '99 will still run it?, and all tq converters from any year will work? So a fbody stall will bolt right up?
Old Feb 26, 2014 | 07:28 PM
mrvedit's Avatar
Moderator
Yes. The torque converter has to be a '98 or later for LS engines.
