4l65e Metal Flakes in Oil
Hey guys I had a cork gasket leak on a trans with only 3k on it so I pulled the pan to replace it... When I did I was sort of shocked to find shavings on the magnet.... When I wiped a cloth through the pan it came up with more shavings... from the picture I would just like to get some opinions on the matter and direction to go. Thanks for the help
Moderator
The direction to go is back to whoever rebuilt the trans. Something is getting chewed up badly. I suppose it could be the converter, but in any case you will have to get both the converter and the trans rebuilt. Also replace any aftermarket cooler and thoroughly flush the cooling lines and stock cooler.
No, you cannot just flush the converter; it also needs to be carefully inspected to see if it is the source of the metal flakes.
Sorry not to have better news.
The trans was basically a mail order deal and it is four years old and out of warranty, what I am trying to decide is if a reputable shop in town would be the way to go or just cut my losses buy a new trans from a good company... I suppose it wouldn't hurt to fill it back up and take it somewhere to get it diagnosed, just don't want to get into $500 of charges and be at square one
