MPG question
Based on your post,you had 2.73s'(2 series carrier) and you now have 3.42s'(3 series carrier OR 2 series carrier with a spacer OR 3.42 'thick' aftermarket gearset. 3.08s' will ONLY work on a 2 series carrier.
for A4
the 3.08 is a guesstimate based on the other data.
2.73-25.9
3.08-24.7
3.23-24.5*
3.42-24.0
3.73-23.0
4.10-22.2
4.56-21.5*
*-my results
if saving money, you would have to drive a long way/time to recover what you lay out for gear changes
if your not cam'ed to big, you could possible bring in your lockup earlier with the higher (neu.) rear and maybe reclaim some milage
Sara (2001 Z28) has 3.73:1 rearend gears, coupled to a 3000 stall 2.5 str, and I get 18mpg freeway, HOWEVER it is a hoot to drive, she runs like a raped ape.
