Think I blew the trans
Where should I start to look to check to see what happened?
thanks
Since you don't even have Reverse, it pretty much has to be the output shaft, the input shaft, input drum or the pump. Since the pump is not excessively strained at WOT, it probably is not the pump. (Correction: it seems the pump, particularly the rotor, is a failure point; see below.)
It can also be a broken flexplate or internals of the converter.
You can check the pump before removing the trans:
1. With engine off, check the trans fluid level.
2. Turn on engine and check trans fluid level again; if the pump is working (and flexplate not completely broken off), the fluid level should drop about one inch, even a bit more.
Obviously the trans and converter need to be removed. Once it is removed, checking the input and output shafts for breakage should be straight forward. The output shaft turns much harder in one direction than the other, but IIRC, when you turn it the hard way, the input shaft will turn too.
If the pump was OK in the dipstick test and the input and output shaft look OK, I would suspect the converter.
Perhaps someone can confirm or correct what I said; I may be overlooking something.
Removing the trans line is the definitive way to test the pump, but the dipstick level test with engine on/off is a simple trick I learned on this forum.
Should be fixed this week.
Its main "feature" is that it replaces the 3/4 clutch snap ring with a bolt-on end-plate. This allows room for one more friction/steel and should eliminate the "coning" problem that can otherwise ruin the 3/4 clutch when running higher line pressure.
No sponsor/builder is going to guarantee this solves the 3/4 clutch problem, but I know it is being used successfully in 700HP pickup trucks.
