What would cause a 4l60e to shift early
This sounds like an engine sensor problem - the PCM does not think you are at WOT. I would check the MAF and TPS first, then the MAP.
Unless the tune changed, the rev limit is not going to change on its own. Maybe your tach is wrong. Can you compare the tach with a scanner?
are set to no MIL, rather than No Error Reported? Short
shifting is a fault response to several things when the
PCM doesn't know what to trust (VSS, TPS, etc.). But
these shift RPM numbers don't seem like that kind of
conservative.
Now these RPM values you say, are they from logs
or from eyeballing the notoriusly slow and inaccurate
tach?
The tach I'm going off of is the autometer digital shift light I have with peak recall
