200k mile 4l60 question
now my question is, is the Dexron 6 ok to use on my car with this many miles? Obviously the dex3 was phased out and I heard the dex6 is a syn blend but it's a tad thinner than dex3 but just lasts longer won't break down as fast yada yada... Would I have any issues using the dex 6?
Sorry if this has been answered a million times
Edit Reply
Today 05:12 AM by Mr Phil
and when I say I have almost no fluid in my transmission, I mean when I pulled out the dipstick, wiped it off and put it back in to check it, the fluid didn't even make it to the cross hatch measuring section that's how low my transmission fluid is
The dipstick is only accurate after a nice drive and the transmission is at full running temperature. Make sure you go through all the gears including reverse.
I'm curious as to why the fluid was low. Anything in the coolant?
If after getting the level correct and you still have a 2-3 issue, drop the pan and change the filter. You may need shift solenoids.
I would definitely drop the pan for a good inspection and a new filter.
And I've had enough bad experiences with stock style in-radiator transmission coolers to never trust them. Any trans fluid in the coolant?
Now Idk if its just cuz of the tune or something else but the 2 tires I kinda got into it (about 50% throttle) going into 2nd it broke loose the first time and chirped the next... Is that normal for these trans? I have hankook ventus v12 whatever for my rear tires with like 90% tread left so I don't think it's my tires just being crappy lol
I'm gonna keep an eye on the fluid levels though and see if they start dropping then I'll have to look for a leak somewhere
Do find out why the fluid was low, even if the prev owner abused it fluid does not get "consumed" (check seal at rear of trans for leak, at driveshaft yoke).
If the pan's leaking, that's a quick and easy fix.
