4l80e swap problems
Old Feb 7, 2015 | 09:20 PM
Turbostude's Avatar
Default 4l80e swap problems
OK, I did the swap in my Studebaker. I went the segment swap route and it didnt seem to work. I read the relay mod thread and swapped over to that, reflashed my PCM and am still having issues. So far all I have done is eliminate a couple DTC's and it is shifting "somewhat". It will shift 1-2 very hard, 2-3 is sluggish and never shifts out to overdrive. The convertor doesn't seem to lock and when at 55-60 it slips in and out. What settings am I missing? I have hptuners...but am pretty green at it. I PM'd slow67, but haven't heard back yet. I don't mind paying for his efforts, I need my truck going again! I'll post my tune in just a bit
Old Feb 7, 2015 | 09:24 PM
Turbostude's Avatar
Here's my tune. It worked great with the 60e until it died!
File Type: hpt
Old Feb 8, 2015 | 06:56 PM
Turbostude's Avatar
Nobody??
Old Feb 8, 2015 | 07:13 PM
Jake's Performance's Avatar
Do you have any codes?
Old Feb 8, 2015 | 09:39 PM
Turbostude's Avatar
It was showing
P0740
P0785
P1860
I went and deleted the DTCs for those codes but it still drives the same. I'm at a loss with this thing!
Old Feb 9, 2015 | 07:12 PM
Originally Posted by Turbostude
It was showing
P0740
P0785
P1860
You disabled the codes in HPTuners? No error reported?
Old Feb 9, 2015 | 08:28 PM
Turbostude's Avatar
Roger that.....3. No error reported
Old Feb 9, 2015 | 09:51 PM
OK,
I think you possibly have the A solenoid staying on, when it shifts to "3rd" and you are shifting from 2nd directly to 4th.
Have you tried to manually command the gear changes in HPTuners scanner?
Have you calculated rpm vs. speed to determine if you are in 3rd or 4th?
Old Feb 10, 2015 | 03:28 PM
Turbostude's Avatar
I'll check that in a bit....any idea why the converter is locking and unlocking?
Old Mar 7, 2015 | 07:07 PM
Turbostude's Avatar
so, the weather finally cleared up enough so I drove the truck to work. It seems to shift hard from 1-2 but the 60 did that too. The biggest issue seems to be 3rd gear. It acts like the convertor locks at first but then slips in and out. I have to get the revs and speed up and it will shift over into fourth and "seems" to be okay.
I havent run a scan yet as my laptop battery crapped out.
Any ideas??
File Type: hpt
