What is the best dex 3
Old 02-18-2015, 09:50 AM
lovethyGM's Avatar
Default What is the best dex 3
Looking for some advice from people who no what there talking about when it comes to trans fluid for 4l60 I don't like what I have in it now going back to Dex 3 I was looking at chevron....
Old 02-18-2015, 11:08 AM
01ssreda4's Avatar
Well what do you have in it now?
Old 02-18-2015, 01:17 PM
mjs1012's Avatar
Any name brand dex3 is fine.
Old 02-18-2015, 01:42 PM
levilz's Avatar
Signature Series ATF. If you want to try it out, shoot me a PM. I can ship it to you for around the same price (or usually a little less) than you can pay for it retail. I use it in my SSS, which tows some and gets beat on pretty regularly, and it runs like a top. Also, I'm currently running the Torque Drive, that this fluid replaced, in my Trans Am, and my trans stayed plenty cool and shifted great. It was a cammed car with a 3200 stall and I wasn't exactly easy it either. lol
Old 02-18-2015, 02:23 PM
01ssreda4's Avatar
I put the syntech or whatever last change. Shifts the same.
Old 02-18-2015, 02:27 PM
Moderator
mrvedit's Avatar
Yes. GM specifies what is in it; nothing more, nothing less.
Old 02-19-2015, 01:07 AM
lovethyGM's Avatar
AMSOIL torque drive
Old 02-19-2015, 09:19 AM
Moderator
mrvedit's Avatar
Originally Posted by lovethyGM
AMSOIL torque drive
It doesn't say "Dexron" on the label; it seems to be formulated for commercial trucks.
Lots of people here (and I) use synthetic Dexron VI, which is now recommended by GM, but I have not seen a single claim that it works better than Dexron 3. Its probably better for 100K mile fluid changes, but I suspect everyone here changes more often than that. Look on Amazon for "Dexron 6 Gallon". Its $24 for AC Delco brand.
Since dropping/draining the pan only gets about 4-5 quarts out and the trans/converter holds 12+, you may need to get a full flush done at a shop. This is a $2000 tool that intercepts the fluid to the cooler - it catches what comes out of the trans with the engine running and simultaneously feeds new fluid into the trans. Whether they use Dexron 3 or 6 really doesn't matter. You can also mix Dexron 3 and 6.
Old 02-19-2015, 02:39 PM
01ssreda4's Avatar
^^^^good advice.
Old 02-20-2015, 09:56 AM
CoolAid's Avatar
Dex VI.
http://www.ls1gto.com/forums/showthread.php?t=359231
And as far as brand, I've taken AutoZone "Coastal" to hell and back with a 4,300 stall in the AZ heat. 230F multiple times. Always bright red. Always smelled "proper". Dex VI is beast fluid.
Dex III is for M6s these days........
Old 02-27-2015, 08:38 AM
thunderstruck507's Avatar
I've always used store brand and it's been fine but last time I switched to Castrol because it was on sale and the fluid looks a little better but the car drives the same.
Really just don't think it matters for the most part.
Quick Reply: What is the best dex 3
