Transbrake Button locations
Old Apr 16, 2015 | 01:40 PM
Papa Wells's Avatar
Default Transbrake Button locations
Hey everyone, not sure if this is the place to post this but I'm trying for it anyways.
I'm in the middle of a 4L80e swap and I need a place to put my transbrake button. I have the B&M Stealth Pro ratchet shifter which does not have a button. I'd like to see where others are mounting their buttons, and I'd like to know what buttons everyone is using. Pictires would be awesome!
Old Apr 16, 2015 | 04:36 PM
1fastrock's Avatar
I'm in the same spot intrested to see what people have come up with
Old Apr 16, 2015 | 04:47 PM
HISS's Avatar
If your using the sheet metal cover I always mounted mine in the rear of the cover.
Old Apr 16, 2015 | 06:52 PM
willizm's Avatar
Mine is mounted on the stock steering wheel. Cheap, simple, and easily accessible.
Old Apr 17, 2015 | 02:33 PM
Papa Wells's Avatar
That's actually a great idea, unfortunately I'm using the 6 speed console and won't be using the metal cover.
Old Apr 17, 2015 | 02:38 PM
Papa Wells's Avatar
Which button are you using, and does the spiral cord get in the way of anything when turning? Does it get hung on the turn signal lever?
Old Apr 17, 2015 | 05:33 PM
willizm's Avatar
The toggle switch in front of the shifter enables the button on the steering wheel which enables the tbrake. The other red button by the shifter was my original tbrake button but found that having it on the wheel is much more comfortable. The spiral cord doesn't get in the way driving on the street although I'm not exactly tokyo drifto'ing the thing around every corner.
Old Apr 18, 2015 | 08:37 AM
Tally TransAm's Avatar
red one is brake. two under the lighter are linelock and converter lockup
Old Apr 21, 2015 | 01:12 PM
Papa Wells's Avatar
Lol! I was just wondering. I'd like to have it on the wheel but I can't decide which button I like.
Old Apr 21, 2015 | 01:13 PM
Papa Wells's Avatar
Good looking setup!
Old Apr 22, 2015 | 06:13 PM
Ratical's Avatar
I'm using my clutch pedal. The neutral safety switch will act as the transbrake button.
