help with torque converter identification
Old May 1, 2015 | 11:06 AM
vinceI's Avatar
Default help with torque converter identification
My boss gave me a converter that he got with an engine he bought. Im trying to find out whos it is but I only have the stampings from the converter and there is not much on it. It looks like a 9 to 10 inch with what looks like a billet bottom. It has "PT0925 1" stamped on it as well as "5 * 00" I have already called pro torque and its not theirs any help if you recognize these markings would be appreciated. Thanks, Vince
Old May 1, 2015 | 11:22 AM
96capricemgr's Avatar
Color?
Old May 1, 2015 | 11:45 AM
vinceI's Avatar
Black
Old May 1, 2015 | 11:52 AM
lemons12's Avatar
Sounds like a PTC... Would have to see it.
Old May 1, 2015 | 12:15 PM
Circle-D's Avatar
Does not sound like our numbers. Post a pic and we will try to help.
Chris
Old May 1, 2015 | 07:58 PM
vinceI's Avatar
These are the best I can get with my phone. Thanks for trying to help.
Old May 4, 2015 | 07:01 AM
vinceI's Avatar
Anybody recognize this? Trying to contact builder to verify if its bushed for use in a turbo splined glide without cutting it open. Thx
Old May 4, 2015 | 08:58 AM
Circle-D's Avatar
Looks like a Transmission Specialties front cover, but no idea who built it. It probably has a bushing in the front cover, you can check by spinning the converter with an input shaft and see if the turbine has any side to side movement.
Chris
Old May 4, 2015 | 10:09 AM
lemons12's Avatar
Looks a lot like a PTC but I don't think it is.
Old May 5, 2015 | 03:07 PM
vinceI's Avatar
Chris
Thanks Chris. I called Trans Specialties and they didn't build it buy they did say they sell their covers around the industry. I put the input in it and tried to push the turbine side to side and if it moves at all its only a very small amount. I think its just the play in the splines so im going to put it in and hope for the best. Thanks for the help, Vince
Old May 5, 2015 | 03:26 PM
lemons12's Avatar
Call PTC.
Old May 9, 2015 | 01:22 AM
Monzsta's Avatar
I've got a Pro Torque billet converter, but that front cover looks a lot lighter than mine. I wonder what it weighs. I think Pro Torque uses the Sonnax cover.
Old May 9, 2015 | 09:01 AM
vinceI's Avatar
Thanks for the reply. Its definitely not a Pro Torque I called them first because of the "pt" in the numbers stamped on it.
Old May 18, 2015 | 07:57 AM
lemons12's Avatar
Did you call PTC (Alabama)?
