torque control
Old Aug 19, 2015 | 11:56 PM
joedirt98ls1's Avatar
Default torque control
How can I tell if my 98 z has torque control
Old Aug 20, 2015 | 07:24 AM
01ssreda4's Avatar
Is it stock? Has it been tuned? There is torque management built into the tune.
Old Aug 20, 2015 | 09:41 AM
It's stock never been tuned
Old Aug 20, 2015 | 10:36 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
I wonder if OP means Traction Control instead of Torque Control ?
Old Aug 20, 2015 | 10:24 PM
mrvedit's Avatar
Moderator
^^+1
joedirt98ls1: why are you asking? What are your trying to do?
Old Aug 20, 2015 | 10:48 PM
I'm wanting to install a shift kit and I read that it is pointless unless you turn off the torque control
Old Aug 21, 2015 | 08:27 AM
redtan's Avatar
Torque management, and yes your car has it. Needs a tune to get rid of it, whether partially or 100%.
Old Aug 21, 2015 | 09:17 AM
bbond105's Avatar
A shift kit is not pointless with torque management turned on. Even with torque management on it will still firm up the shifts and the boost valve will still increase the line pressure. Which in turn helps the trans live longer.
Old Aug 21, 2015 | 11:02 AM
whats a good shift kit to use ive always used b&m transpaks but ive heard a lot of guys say transgo which seem a little high for the good one and not to mention you have to remove the tranny to install
Old Aug 21, 2015 | 04:11 PM
bbond105's Avatar
Most use the TransGo 4L60E-HD2-C kit. If the trans is not out of the car the kit instructions say to just do the parts of the kit that can be done without removing the trans. Skip the part on page 5 with the reverse input piston if trans is in the car. On page 2 step 3 do not install more than one spacer, it makes the trans shift too hard and breaks the sprag. On page 4 step 1 the knowledgeable people on here prefer the Sonnax .490 O-Ring Boost Valve over the .500 TransGo Boost Valve. The o-rings on the Sonnax valve help stop fluid leaks where it fits into the pump bore and the steel TransGo boost valve sleeve wears the pump bore out faster.
Attached Thumbnails torque control-page-1.jpg   torque control-page-2.jpg   torque control-page-3.jpg   torque control-page-4.jpg   torque control-page-5.jpg
Old Aug 24, 2015 | 12:33 PM
01ssreda4's Avatar
Trans go HD2 all the way bud.
