B&M deep pan......
Old Jan 1, 2016 | 11:54 PM
01Z0H6's Avatar
Default B&M deep pan......
Who's running these? On lowered cars.
Adding a Yank SS3600 in a couple of weeks along w B&M 24GVU cooler... Was thinking of adding a deeper pan for piece of mind. Lets hear your experiences, and see some pics if possible. Thanks.
Old Jan 2, 2016 | 07:14 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
I ran a TCI deep pan for quite a while. Don't know how the TCI pan compares to the B&M pan as far as depth. I'm stock height and it was still an area of concern due to how it was the lowest part underneath. I ended up fracturing it and it began to seep fluid in the fractures. Could have been catastrophic had it been broken instead of fractured. Cast aluminum has no strength to resist the impact weight of the vehicle when touching a speed bump.
Old Jan 2, 2016 | 08:02 AM
01Z0H6's Avatar
It's funny you say that... I too (years ago) had a lowered 00Z28 w the B&M pan... I seemed fine as I recall... I made a uturn over one of those turtle shell speed bumps and fractured mine....
I wonder about the truck pans.....?
Old Jan 2, 2016 | 08:20 AM
The only advantage to a deep aluminum pan was having a drain plug to prevent the mess of dropping a regular pan. There are a few threads recommending a truck pan because they're stamped steel. Why are you concerned about running a deep pan since you're gonna have a cooler ? I'm currently back to running the OEM pan.
Old Jan 2, 2016 | 09:05 AM
01ssreda4's Avatar
Im running this one, its steel and has a drain AND a temp bung for my sending unit. It did make a difference in temps.
Old Jan 2, 2016 | 09:08 AM
Tracer Bullet's Avatar
Sooooo, details on said pan? Looks enticing
Old Jan 2, 2016 | 09:10 AM
01ssreda4's Avatar
http://derale.com/products/transmiss...fitting-detail
Old Jan 2, 2016 | 09:31 AM
^^^ thanks !
Old Jan 2, 2016 | 09:37 AM
mrvedit's Avatar
Moderator
Some members with 500HP+ have noted slippage during shifts with the stock pan because it appears the fluid pickup get uncovered. Their solution is to overfill the trans by 1/2 quart. The truck pan with 1 quart more capacity is known to solve this.
I run a +1 quart aluminum pan. Avoid any chrome plated pans as the chrome deteriorates over time and then causes leakage. Any +2 quart pan will sit too low to be safe.
Sorry, but there are plenty of negative posts about the Derale pan, including this one:
https://ls1tech.com/forums/automatic...oling-pan.html
Old Jan 2, 2016 | 10:00 AM
01ssreda4's Avatar
Let me clarify, I dont believe their marketing BS. That being said, this pan is steel, it will dent before crack, it holds more fluid, and it has a sending unit bung already and being steel is easily repaired or altered. It also retains use of a stock filter depth. Win win win. I dont give two craps about what some jerk says about how his temps skyrocketed and tries to blame the pan. He is a moron. I bought it for the reasons stated above AND I did see my temps drop slightly. Ive been monitoring trans temps on this car with a digital gauge for 7 straight years. I may know a thing or two about its patterns.
Old Jan 2, 2016 | 01:58 PM
mrvedit's Avatar
Moderator
^^^ Gotcha.
I would not expect it to cool much, if at all, and certainly not an alternative to a real cooler. You obviously had realistic expectations that it fully satisfied.
Since its spec is 2+ quarts, doesn't it sit rather low though?
Old Jan 2, 2016 | 02:12 PM
01ssreda4's Avatar
I have a pic of it somewhere. Obviously I was a little worried about that. I remember looking and noticed the trans pan is higher then most everything else when stock, now its about even. Problem is if you rub the underside of the car it will likely be towards the middle of the car and there are no wheels there to ride over the bump. So yeah I think about it but no issues as of yet. I admittedly don't drive my car often so I'm not the best example.
Old Jan 2, 2016 | 07:27 PM
clinebarger's Avatar
A factory deep pan is $20,
Amazon.com: ACDelco 24240207 GM Original Equipment Automatic Transmission Fluid Pan: Automotive Amazon.com: ACDelco 24240207 GM Original Equipment Automatic Transmission Fluid Pan: Automotive
I have seen to many Cast pans get busted on F-bodies to recommend running one.
Old Jan 3, 2016 | 07:30 AM
01Z0H6's Avatar
says that it does not fit?
Originally Posted by clinebarger
A factory deep pan is $20, Amazon.com: ACDelco 24240207 GM Original Equipment Automatic Transmission Fluid Pan: Automotive.
Old Jan 3, 2016 | 08:36 AM
01ssreda4's Avatar
Probably because its not original equipment.
Old Jan 3, 2016 | 08:58 AM
madmike9396's Avatar
I'm running the summit deep pan on mine with a big Derale cooler. I will try to take pics later today. I'm on bilstein shocks and BMR springs.
the lowest part of my car it the torque arm
Old Jan 3, 2016 | 09:00 AM
Aluminum cools better than steel keep that in mind
Old Jan 3, 2016 | 02:53 PM
01Z0H6's Avatar
Get me those pics please.... I too am running Bilstiens but with the Pro Kit ( bought it that way). I am looking to change springs as I do not like the way the eibach's feel ( personal preference). The rest of my suspension is BMR... I am looking to go BMR springs or Strano's.... Pics please...
Old Jan 3, 2016 | 04:22 PM
Stance
Driver side
Passenger side
My summit pan tucks up nicely between the headers. You barely can see it.
really need to jack it up to get good pics
Old Jan 3, 2016 | 04:26 PM
I know a guy that had issues with his. Finally took it off
