Transmission filter fitment?
Old Feb 5, 2016 | 04:46 PM
ggino85's Avatar
Default Transmission filter fitment?
Hey quick question, I just removed the old filter seal and pressed in a new one with a 3/4'' socket. That all went smoothly but when i installed the filter it looks like it's sitting at an angle and not flush up against the bottom of the transmission. Does the filter sort of slope a bit? i can get a picture if needed.
Old Feb 5, 2016 | 05:21 PM
coryforsenate's Avatar
Check the gasket that's in the hole the filter inserts into and make sure it's in there straight (is this new or old filter gasket?). The filter body should be fairly parallel with the valve body.
Picture would be great. Your idea of slanted may be different than others'.
Old Feb 5, 2016 | 05:24 PM
ggino85's Avatar
new filter gasket. i made sure the gasket is flush inside where it fits before installing the filter. But i couldn't get the filter to sit parallel. It kind of sags down towards the rear.
Old Feb 5, 2016 | 05:26 PM
98CayenneT/A's Avatar
Should be parallel like said above, my guess is it's not all the way seated and you may have to push the filter in harder
Old Feb 5, 2016 | 06:14 PM
ggino85's Avatar
Thank you guys for your quick responses....... i was able to get the filter a little more parallel but its not flush up to the tranny like i would imagine it should be. Im charging my phone right now it was too dead to take a picture. I'll have it up in a couple minutes.
Old Feb 5, 2016 | 06:24 PM
ggino85's Avatar
Sorry for the delay. I removed it completely (it was really hard to remove) and re-installed it and it pops in very snug but back into the same position as in the photo.
Attached Thumbnails Transmission filter fitment?-20160205_161714.jpg   Transmission filter fitment?-20160205_161721.jpg
Old Feb 5, 2016 | 06:57 PM
ggino85's Avatar
and some fluid from the pan. Looks pretty dark
Old Feb 5, 2016 | 08:23 PM
bbond105's Avatar
The filter is pushed too far into the seal. Pull it out of the seal a little until it is level but be sure you don’t pull it completely out of the seal.
Old Feb 5, 2016 | 10:28 PM
ggino85's Avatar
i did push the filter in there pretty good. I'll pull it out a little tomorrow morning.
