Rookie 4l60e rebuild
#142
Remember that the PCM/TCM completely controls the shifting. So if the trans is shifting earlier, it is because the PCM/TCM told it to.
If the PCM starts the shift at 5000 RPM and the trans doesn't complete the shift until 6000 RPM, then there is a problem.
As Clinebarger mentioned, the tuner may have bumped the shift pressures more than needed to try to compensate for the excessive band clearance.
In short, this is a tune issue, there is nothing wrong with your trans.
#143
Just talked to my tuner and he said bring it in Thursday morning and he will have no problem getting it squared away.
#144
Figured I would do one more update.
Got my car back from my tuner a while back and it's good to go.
Headed back to the track this past Saturday and mad 8 solid runs with zero issues. The car really has never felt this good and solid. It seems I am officially good to go.
Consistent 12.2x with 1.7x 60's
Car 704
Car 704
#145
Other than a "wait I'm still eating my sandwich" reaction time, it looks very good.
You did a great job rebuilding your trans. I'm sure you are proud of that and no longer fear transmission problems.
#146
Thanks, it really does feel good. It's kind of nice also to know depending on what goes out in the future I can have it out, go threw it and back in and if need be, possibly a 1-2 day turnaround instead of pull it out, bring it somewhere, wait, get it back not knowing exactly what was done and put it back in for a total of 1-2 week turnaround.
I definitely had fun.
I'm thinking of buying a core and doing another one on the side, maybe as a winter project and going a step or two farther than I did with this one with stuff I have learned from you guys threw the many threads
I owe you guys
#148
Seeing how many pro builders use the cheaper Dex 3 fluid, any Dex 6 may already be overkill (although I use it). GM determines the specs of anything labeled Dexron 6 (it is their trademark) and I therefore doubt a high priced brand will be any better if even any different.
#150
Ya, I will do that when I get some time post up parts, tools used and clearances. I have about 4,000 mi. on it and have not had so much as a hitch.
#151
First pan drop since rebuild after about 4,500 miles.
I'm happy with what I see. No mucky swamp on the bottom of my pan lol.
Just a thin film of clutch dust on the magnet which I'm assuming is normal wear.....
#152
Transmission worked flawless with bolt ons and converter with 1.7x 60's.
Added H/C, more converter and more rpm and away she went on the street yesterday. 1.5x 60's and 7000 rpm shift points.
Think I may have broke the forward sprag in a wot pull on the street.
Manual first holds. In d3 and D.....2nd, 3rd slip and sometimes 1st....... possible pump issue also?
Going to rebuild it one more time before I go to a 4l80e.
Edit: I'm now thinking the forward sprag broke.
#153
The forward sprag is the weakest link in the 4L60E.
I got this info from PBA (Dana) at Pro-Built Automatics. Following these instruction helped with my trans.
The later 29 element sprag from Borg Warner has wider elements PN is A74658D (Transtar number). The elements are 12.7% wider than the normal BW sprag. It is a "dual cage" and one of the cages is nylon, and the other has bronze guides instead of the steel ones. It must be used with a 4L60E overrun hub. You should grind in 6 oil slots on the bronze guide that faces the overrun hub for better oiling like the steel guides have. Use the steel guide as a "template" for adding the oil slots. I have used these for when the normal sprag has been problematic.
The inner race must have no wear and must be perfectly flat and have a "mirror" finish. The outer race should be flat and rough. Use 36 grit sand paper and sand it in the direction of rotation by rolling it across a wooden bench and do it about 15 - 20 times. Rinse with solvent and blow it off with high pressure air. The later sprag can be identified by one of the two cages is plastic. I offer these in my Pro Street Elite rebuild kits.
#155
Did you do the following?
#157
#158
Don't feel like re pinning a new pcm either.
#160
