Th400 speed sensor
Gm part # 8655291
Standard part # sc191
AC DELCO ROTOR PART # 8655315
AC DELCO PLUG 12085498
CK PERFORMANCE SENSOR PART # 400-SP/VSS
CK PERFORMANCE ROTOR PART # 400-SP/VSSR
CK PERFORMANCE PLUG PART # 400-SP/VSSC
I'll put this here also since they go hand in hand. https://ls1tech.com/forums/gears-axl...-end-swap.html
I wonder why nobody makes these 8655291 / 24232618 new anymore? The older 4l60 ones are everywhere new.
Compared to early 4l60 sensor here... the 60 sensor is a little shorter, and the OD is larger. If the 60s OD was milled down and it was pushed in a little further it seems like it would be about in the right place to perhaps pickup a signal. Of course the bracket is wrong too so that would need some work.
I am going to see about designing the sensor body and 3D printing it and using an alternate VSS, like for a T56. Some thing like this:
Thanks!
Andrew
problem i see is i only have a 3 axis machine so its going to be a bunch of ops or two pieces?
anyway, if i ever make them ill let you know. the plan would be to sell them.
Could use stock O ring
and would be capable of temps needed for that area of the trans.
Most ABS filament has a glass transition temp of 220 ish F
And a true melting temp of 400+
It would certainly be worth a try!
I may draw up 2 varieties. One with a VR sensor which would work with stock pcm's
then another with a Hall effect sensor which is better suited to work with aftermarket (holley/haltech/etc) ecu's
Alternatively, an easier solution (especially for aftermarket ECU's) is to use a driveshaft ring and sensor setup. They're super common and reliable.
If you must use the OEM wheel for tooth count on a stock ECU, you can get a 3/8 threaded VR sensor, and cleverly drill/tap the case to align that sensor with the ring. Not as pretty, but much more affordable than tracking down a 20 year old sensor that may be a crap shoot.
Thanks!
