4l60e hitting rev-limiter
The tune needs to be looked at via Hp tuners and you need to do a data log of a run and see if you are meeting the mph/rpm for the shift to take place.
It might need adjusting
However, if an unchanged setup starts hitting the rev limiter, I would also suspect the 3/4 clutch is worn if it occurs on the 2->3 shift; especially because this is one of the most frequently reported problems here. If it occurs on the 1->2 shift, then the band is likely worn.
I also suggest overfilling the trans by 1/2 quart if you have the stock shallow pan; it is not necessary if you have the truck or other larger capacity pan.
I don't agree with the "You can't hurt the trans overfilling it either" comment, but don't have the experience to know what then happens. The 1/2 quart overfill is fine.
Remember that the trans level has to be checked with the engine running; it will read about 1" higher on the dipstick with the engine off.
