4L60E 2-3 shift flare solved!
Thanks to someones post here on Ls1tech that said to carefully over fill the trans oil level slightly my problem was solved! Apparently when you increase how your car launches the oil can flush back on these 4l60E's and loose line pressure. This was exaggerated with my trans slightly tilted downward. I also read that converting to the truck oil pan (because its slightly deeper) and slightly overfilling the trans level can stop this.
DON,T OVER-DO IT THOUGH! TOO MUCH WILL HIT THE SPINNING PARTS IN YOUR TRANSMISSION AND FOAM UP THE OIL AND BLOW IT UP.
I was searching this site and others when this started and saw many had transmissions rebuilt and replaced and spent tons of $$$ only to suffer from the same issues. I thought I was in for expensive repairs when all this time it was $5 bottle of trans fluid. Hope this solves your problems.
As you mentioned, install the truck pan also helps.
Strange that installing the HD2 kit made things worse; I suspect there was a problem with the boost valve.
What year is your 4L60E?
I recommend the Sonnax boost valve even when installing the HD2 kit.
Fairly certain it led to premature 3-4 clutch failure in mine before. It had started slipping again at WOT on 2-3 highway pull shifts, added 1 qt fluid and it went away.
Come to find out the Lokar dipstick was not correct as far as the "full" mark was concerned. I discovered it while I had the pan off to replace the filter in hopes of making the trans last a little longer...ever since filling it more it's been flawless.
I wondered if 60 & 80E trans were built with the min. amounts of fluid, you know, weight saving, gas mileage, etc-a little here, a little there to get down to certain Gov. imposed #'s, lol
Good info, esp since you proved it
