Need help asap! 4l60e issue!
2nd chapter...
I ordered the new transmission, and the one they sent me for the car and what it supposedly calls for is the 4l60e, but when i got it, it has a black box on the side, an MLPS or neutral safety switch. My car does NOT have those harness plugs to fit that black box! What do i do!? Is there a way to still use the transmission? Like i said i had to get a loan to get the transmission so i can drive to and from work, i dont hae all thw extra money in the world to just waste. I would really appreciate any and everybodys help. Im not looking for arguments or bullcriticism in this thread.....
Thank you..
One thing to check is whether your shifter cable connects properly to the shifter shaft which goes through the black box. Some (trucks?) have a longer shaft which might not work with your car. While not trivial, a trans shop could easily swap in the shorter shaft.
Connecting the Park/Neutral switch to the PCM does not implement the Park/Neutral safety feature; at least it doesn't on my car. Therefore either it is implemented in a different way or your car doesn't have a Park?Neutral safety switch.
Assuming you have an aftermarket shifter, you will have to determine if the existing cable will work for you. With an aftermarket shifter you will also want to change its operation from 3 speed to 4 speed.
What shifter do you have?
The Shift Shaft is EASY to change!! I will give instructions if needed.
There is a difference between Fabricating & Rigging, I'm going to have too file this under Rigging (Yes I've been told I lack Tact).
As long as you still have the 13-wire harness that connects to the trans, and can get the shifter connected, you are good to go. Obviously you also need a LS-style converter.
Before installing the trans make sure the holes in the flexplate align with the converter.
When installing the converter MAKE SURE and measure with a ruler that the converter pads are at least 1" from a straight edge held over the bellhousing. Anything less and the converter is not fully seated and you will ruin the trans when you bolt it up.
I can't help you with the shifter cable since I don't have a Gen-4, but Clinebarger has offered to give you more instructions. You can remove the black box if you need to - that won't affect your warranty since you can easily put it back on.
https://ls1tech.com/forums/automatic...allations.html
And other threads:
https://ls1tech.com/forums/automatic...important.html
https://ls1tech.com/forums/automatic...ease-help.html
https://ls1tech.com/forums/automatic...1-1-16-ok.html
