4l60e input shaft and torque converter options
Old Nov 26, 2016 | 04:51 PM
animalcrackerzrgood's Avatar
Default 4l60e input shaft and torque converter options
I am getting close to bolting a 4l60e up to a built LNF ecotec in my Solstice GXP. I modified the bell so I could bolt it up. I used an '02 Camaro V6 4l60e for a few reasons. Dowels line up on an ecotec and center the crank and the torque converter has a .825" pilot which is the same as an ecotec as well. I also have a spare V8 4l60e that Ive been comparing. So my questions...
Should I be concerned with a V6 input shaft handling 500whp? It looks so much smaller than the V8 input shaft.
Do torque converters have a limit on the power/rpms they can handle? I was gonna run the stock V6 converter for a bit if possible. Only spinning 7200rpm.
Is there a vendor that can make a custom converter so I can get a 3600 stall, use a 300mm input shaft , .825" pilot and possibly an ecotec flex bolt pattern? I think I can just elongate the holes on the ecotec flex but if it can be built Id rather just get that done too.
Old Nov 26, 2016 | 06:02 PM
Islandcutlass's Avatar
Here is a good guy for you to contact. His name is Paul, and you can call him at 1-800-xxx-xxx. He will give you the answers you are looking for. The company he works for makes all manner of hardcore/high performance parts and can build you any converter you require.
EDIT: Sorry direct contact info to non-sponsors is not permitted by forum rules.
Old Nov 26, 2016 | 06:59 PM
mrvedit's Avatar
Moderator
The sponsors FTI and CircleD are very active helping members and answering questions on this forum. Both can build a custom billet converter.
Old Nov 26, 2016 | 07:37 PM
Ok Ill contact them and see what options I have.
Should I even be worried about an input shaft failure at 500 wheel?
Old Nov 29, 2016 | 01:49 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
We actually build a converter for the V6 Camaros so im sure we could accommodate a converter for you(custom built of course)
regards to the input shaft, it SHOULD be a 27 spline input shaft(same as 200r4/700r4) and will hold up no problem to you 500HP
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Nov 30, 2016 | 07:19 AM
Thanks. I completed the torque converter sheet this morning to get the ball rolling.
Old Dec 4, 2016 | 10:01 PM
gbgn1's Avatar
Im using the same trans set up and talked to sonnex a month ago or so about a billet input shaft (245mm)and they wanted me to use a 298mm shaft and have a custom convertor made . Said there wasnt enough demand for 400 shafts to be built. sucks. Im thinking of getting a 300mm and having a machine shop turn it down to a 245mm. looks very doable.
