Vacuum Mod - 4l80e - Check valve
I've done the vacuum modulator modification on my 4l80e.
I need to put in a check valve in the vacuum line from the motor to the modulator.
I've eliminated all visible/external rubber vacuum lines on my motor and converted them to nylon line with push-connect fittings.
I'm trying to put in a check valve for this vacuum modulator that doesn't use a hose clamp and hose barb.
What check valves/arrangements have you guys used on this mod?
Are you running boost? you shouldn't need a ck valve-I used one of those TCI I think vents to blow out boost, but it was nippled.
If you use a ck valve, depending on how its installed, you would end up holding vac. against the mod, or not getting vac to it-think power booster for brakes, what the ck valve does
Yes, I'm running boost.
I understand how a check valve works.
The check valve goes in a tee off the main vacuum feed so that it closes under vacuum to communicate with the modulator, but bleeds off boost and doesn't damage the diaphragm in the modulator.
I also need to track down an orifice fitting, with, I believe, around .050" hole.
Here's what I ended up with. It's not pretty, but it'll get the job done long after I'm dead.
Important fittings: #3- jic .047" orific fitting, #7(top)- check valve
